14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
12 years agoDave,
I have a situation where I get stale data back to the RC from the ArriaV or Cyclone IV endpoints ... Has to be a logical issue rather than FPGA or Timing. I write to a constant location and read back the same location then compare ... then move on to a new write pattern. It passes until I start the NIOS , even if I just perform a single printf and return. After that I get stale data ... ie the data from the previous iteration of the test ... where the data I get is the data that was written say 8 writes back , sometime more , sometimes less but a constant. I am trying to see in Simulation and setting "Singel DW completer" on. Seen anything like this before ? Thanks, Bob.
