14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
14 years agoDave,
Where is this failing timing? I am currently 'debugging' a design that is.. Quartus 11.0 (I can't run the Qsys system through 11.1, even if I regenerate the Qsys system in 11.1 [which I can do without error]). Custom board Cyclone IV x1 Hard IP PCIe end-point with 125Mhz application clock Simple memory mapped interface to custom logic. This is failing on core-clock -> core clock transfers internal to the hard IP according to Timequest. As far as I can see everything's constrained properly. [Edit] I forgot to say the board's been built with '7 devices, the PCIe spec says the core should work on '8s.[/Edit] I've been meaning to raise a SR for about a week but if you could get it sorted out that would be very helpful. :) Nial
