10 years agoQsys new component: char LCD, 8-bit or 4-bit selection?
Hi all, I'm new to FPGAs and I want to make a new component in qsys. I saw the ip for Optrex 16207 LCD controller core and there also another in "altera\15.0\ip\altera\sopc_builder_ip\altera_av...
10 years agoYou can display parameters and have the user configure them. Not sure you can do anything graphical (i.e. picture of the LCD).
What do you mean by# defines? Sounds like C code not HDL. Or do you mean the `define statements in Verilog? Really you should be using parameters in HDL rather than `defines. The parameters can then be displayed in Qsys and the user set the values (these will be embedded into HDL code generated by Qsys).
