14 years agoQsys generates PCIe designs that do not compile.
Hi, I have recently updated Quartus installation from 11.1 to 11.1sp2 (Subscription Edition). I can compile previous Qsys designs with PCIe, but when create a new design, compilation stops duri...
14 years ago --- Quote Start --- Apparently the `default_nettype setting is preserved across compilation of different verilog sources, and thus the result depends on the order of compilation. I prefer to enable `default_nettype none, to avoid hard to find bugs caused by typos in net names. It seems sufficient to place `default_nettype wire at the end of each file where I change this setting - now the design compiles. --- Quote End --- This is one reason I like to script the final design. If there are compilation ordering issues, it helps to 'encode' those requirements in the script. --- Quote Start --- As for your problems with timing, I am using only Arria II GX and I used to have some timing errors. For me it was sufficient to precisely specify all clocks, enable all optimizations for timing, and add these entries in the top-level .sdc file: derive_clock_uncertainty derive_pll_clocks --- Quote End --- Yep, I have all this, and TimeQuest shows the design is fully constrained. --- Quote Start --- In 11.1 it was also necessary to add this: set_clock_groups -asynchronous -group [get_clocks {alt_cal_edge_detect_clk}] In 11.1sp2, no clock is matched for that setting, so I suppose it is not needed anymore. I must run some further tests to check if the design works stably, though. --- Quote End --- I get the timing errors under 11.1sp2 as well, so its probably not this. However, I'll take a look at the clocks and see. Thanks for the pointer. Cheers, Dave
