Adithiya_R's avatar
Adithiya_R
11 months ago
PTILE + PIO Example design
For the Ptile+PIO example design, with Intel BFM --- in endpoint config, if we replace the PIO instance with CUSTOM_LOGIC, we can perform
  1. BAR0 ( MemWr, MemRd) --- ( BFM, PTILE_EP---> Custom Logic)
  2. Similarly, we can also initiate MemWr, MemRd ( Custom Logic ---> PTILE_EP ---> BFMs Shared Memory)
  3. But in the current BFM, is there a provision to exercise Interrupt ( legacy, MSI/MSI-X)?
  • Wincent_Altera's avatar
    Wincent_Altera
    Hi Adithiya,
    I just try to understand what you going to do before we actually go into your question.
    >> Okay, if I understand correctly that will be the reason you using custom logic instead of build in Intel BFM right ?
    1. But in the current BFM, is there a provision to exercise Interrupt ( legacy, MSI/MSI-X)?
    >> I not sure how you perform your custom logic , but theoretically you can enable these capabilities in your custom BFM instance
    >> BUT ensure your custom logic generates the correct signals or memory writes as per the PCIe specification.
    Wincent_Altera
      Wincent_Altera
      Hi ,
      Given that there is no any response on this case , I assume you had found the solution somewhere else.
      Do let us know back if you need any other help.
      Wincent
