17 years agoProblems with TSE IP Core
I seem to be having trouble with the TSE Core. I am using: - Stratix II GX Board - USB Blaster Cable - Quartus 8.0 - Nios II Devleopment Suite 8.0 I am able to download the SOF file to the board either using the quartus_pgm tse_ref_design_top.cdf command as listed in the documentation, or with the Quartus software, but when I try to download the main.elf file, I get the following error: [niosii eds]$ nios2-download-g main.elf; nios2-terminalusinb cable "usb-blaster [usb-0]", device 2, instance 0x00
assertion "m_state == state_debug" failed: file "nios2oci.cpp", line 157
7 [sig] nios2-gdb-server 1260 e:\altera\8.0\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1
/cygdrive/e/altera/8.0/nios2eds/bin/nios2-download: line 594: 1260 hangup
nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./main.elf.srec
nios2-terminal: there are no jtag uarts available which match the --device and
nios2-terminal: --instance options you provided. Does anybody have any ideas? I am absolutely stumped on what the problem is. Thank you edit: i should have said that this is the tse data path reference design ... but anyways, it seems to be working now, without me changing anything ...
Look on the USB Cable box - what's its revision - B or C? rev.B doesn't work properly with nios2-terminal due to bad niose immunity. Altera mentonied this in the knowlidge base.
No, I have a rev C. USB Blaster.
