16 years agoproblems with the sdram_input_efifo_module
sdram_input_efifo_module is one module from the SDRAM IP core(sdram.v) which offerred by ALTERA.I cannot understand how this module works,can someone gives me a explanation?
following the program module sdram_input_efifo_module ( // inputs: clk, rd, reset_n, wr, wr_data, // outputs: almost_empty, almost_full, empty, full, rd_data ) ; output almost_empty; output almost_full; output empty; output full; output [ 43: 0] rd_data; input clk; input rd; input reset_n; input wr; input [ 43: 0] wr_data; wire almost_empty; wire almost_full; wire empty; reg [ 1: 0] entries; reg [ 43: 0] entry_0; reg [ 43: 0] entry_1; wire full; reg rd_address; reg [ 43: 0] rd_data; wire [ 1: 0] rdwr; reg wr_address; assign rdwr = {rd, wr}; assign full = entries == 2; assign almost_full = entries >= 1; assign empty = entries == 0; assign almost_empty = entries <= 1; always @(entry_0 or entry_1 or rd_address) begin case (rd_address) // synthesis parallel_case full_case 1'd0: begin rd_data = entry_0; end // 1'd0 1'd1: begin rd_data = entry_1; end // 1'd1 default: begin end // default endcase // rd_address end always @(posedge clk or negedge reset_n) begin if (reset_n == 0) begin wr_address <= 0; rd_address <= 0; entries <= 0; end else case (rdwr) // synthesis parallel_case full_case 2'd1: begin // Write data if (!full) begin entries <= entries + 1; wr_address <= (wr_address == 1) ? 0 : (wr_address + 1); end end // 2'd1 2'd2: begin // Read data if (!empty) begin entries <= entries - 1; rd_address <= (rd_address == 1) ? 0 : (rd_address + 1); end end // 2'd2 2'd3: begin wr_address <= (wr_address == 1) ? 0 : (wr_address + 1); rd_address <= (rd_address == 1) ? 0 : (rd_address + 1); end // 2'd3 default: begin end // default endcase // rdwr end always @(posedge clk) begin //Write data if (wr & !full) case (wr_address) // synthesis parallel_case full_case 1'd0: begin entry_0 <= wr_data; end // 1'd0 1'd1: begin entry_1 <= wr_data; end // 1'd1 default: begin end // default endcase // wr_address end endmoduleNo RepliesBe the first to reply
