13 years agoProblems with simulation of DDR2 SDRAM Controller with UniPHY
Hi, I Am using the files for simulation in generated for this IP . The IP is configured to enable Hard external memory controller, in Aria V, Quartus 12. The DDR2 SDRAM Controller is set...
13 years ago> "assign afi_half_clk = 1'b0;"
I provide my workaround for above issue as follows: S/W: Quartus II 12.0, SP2 Modified file: /[FPGA_PROJECT]/[QSYS_NAME]/synthesis/submodules/[QSYS_NAME]_uniphy_ddr3_pll0.sv 1. find the following codes: altpll upll_memphy ( .areset (areset), .inclk (inclk), .clk (pll_clks), .locked (pll_locked), .activeclock (), .clkbad (), .clkena ({6{1'b1}}), .clkloss (), .clkswitch (1'b0), .enable0 (), .enable1 (), .extclk (), .extclkena ({PLL_PHASE_COUNTER_WIDTH{1'b1}}), .fbin (1'b1), .fbmimicbidir (), .fbout (), .fref (), .icdrclk (), .pfdena (1'b1), .pllena (1'b1), .scanaclr (1'b0), .scanread (1'b0), .scanwrite (1'b0), .configupdate(1'b0), .scandata(1'b0), .scandataout(), .scandone(), .phasecounterselect({PLL_PHASE_COUNTER_WIDTH{1'b1}}), .phasedone(), .phasestep(1'b1), .phaseupdown(1'b1), .scanclk(1'b0), .scanclkena(1'b1), .sclkout0 (), .sclkout1 (), .vcooverrange (), .vcounderrange () ); defparam upll_memphy.bandwidth_type = "AUTO"; defparam upll_memphy.clk0_divide_by = PLL_AFI_CLK_DIV; defparam upll_memphy.clk0_duty_cycle = 50; defparam upll_memphy.clk0_multiply_by = PLL_AFI_CLK_MULT; defparam upll_memphy.clk0_phase_shift = PLL_AFI_CLK_PHASE_PS; defparam upll_memphy.clk1_divide_by = PLL_MEM_CLK_DIV; defparam upll_memphy.clk1_duty_cycle = 50; defparam upll_memphy.clk1_multiply_by = PLL_MEM_CLK_MULT; defparam upll_memphy.clk1_phase_shift = PLL_MEM_CLK_PHASE_PS; defparam upll_memphy.clk2_divide_by = PLL_WRITE_CLK_DIV; defparam upll_memphy.clk2_duty_cycle = 50; defparam upll_memphy.clk2_multiply_by = PLL_WRITE_CLK_MULT; defparam upll_memphy.clk2_phase_shift = PLL_WRITE_CLK_PHASE_PS; defparam upll_memphy.clk3_divide_by = PLL_ADDR_CMD_CLK_DIV; defparam upll_memphy.clk3_duty_cycle = 50; defparam upll_memphy.clk3_multiply_by = PLL_ADDR_CMD_CLK_MULT; defparam upll_memphy.clk3_phase_shift = PLL_ADDR_CMD_CLK_PHASE_PS; defparam upll_memphy.clk5_divide_by = PLL_NIOS_CLK_DIV; defparam upll_memphy.clk5_duty_cycle = 50; defparam upll_memphy.clk5_multiply_by = PLL_NIOS_CLK_MULT; defparam upll_memphy.clk5_phase_shift = PLL_NIOS_CLK_PHASE_PS; defparam upll_memphy.clk6_divide_by = PLL_CONFIG_CLK_DIV; defparam upll_memphy.clk6_duty_cycle = 50; defparam upll_memphy.clk6_multiply_by = PLL_CONFIG_CLK_MULT; defparam upll_memphy.clk6_phase_shift = PLL_CONFIG_CLK_PHASE_PS; defparam upll_memphy.inclk0_input_frequency = REF_CLK_PERIOD_PS; defparam upll_memphy.intended_device_family = DEVICE_FAMILY; defparam upll_memphy.lpm_type = "altpll"; defparam upll_memphy.operation_mode = "NO_COMPENSATION"; defparam upll_memphy.pll_type = "AUTO"; defparam upll_memphy.port_activeclock = "PORT_UNUSED"; defparam upll_memphy.port_areset = "PORT_USED"; defparam upll_memphy.port_clkbad0 = "PORT_UNUSED"; defparam upll_memphy.port_clkbad1 = "PORT_UNUSED"; defparam upll_memphy.port_clkloss = "PORT_UNUSED"; defparam upll_memphy.port_clkswitch = "PORT_UNUSED"; defparam upll_memphy.port_fbin = "PORT_UNUSED"; defparam upll_memphy.port_fbout = "PORT_UNUSED"; defparam upll_memphy.port_inclk0 = "PORT_USED"; defparam upll_memphy.port_inclk1 = "PORT_UNUSED"; defparam upll_memphy.port_locked = "PORT_USED"; defparam upll_memphy.port_pfdena = "PORT_UNUSED"; defparam upll_memphy.port_pllena = "PORT_UNUSED"; defparam upll_memphy.port_configupdate = "PORT_UNUSED"; defparam upll_memphy.port_scandata = "PORT_UNUSED"; defparam upll_memphy.port_scandataout = "PORT_UNUSED"; defparam upll_memphy.port_scandone = "PORT_UNUSED"; defparam upll_memphy.port_phasecounterselect = "PORT_UNUSED"; defparam upll_memphy.port_phasedone = "PORT_UNUSED"; defparam upll_memphy.port_phasestep = "PORT_UNUSED"; defparam upll_memphy.port_phaseupdown = "PORT_UNUSED"; defparam upll_memphy.port_scanclk = "PORT_UNUSED"; defparam upll_memphy.port_scanclkena = "PORT_UNUSED"; defparam upll_memphy.port_scanaclr = "PORT_UNUSED"; defparam upll_memphy.port_scanread = "PORT_UNUSED"; defparam upll_memphy.port_scanwrite = "PORT_UNUSED"; defparam upll_memphy.port_clk0 = "PORT_USED"; defparam upll_memphy.port_clk1 = "PORT_USED"; defparam upll_memphy.port_clk2 = "PORT_USED"; defparam upll_memphy.port_clk3 = "PORT_USED"; defparam upll_memphy.port_clk4 = "PORT_USED"; defparam upll_memphy.port_clk5 = "PORT_USED"; defparam upll_memphy.port_clk6 = "PORT_USED"; defparam upll_memphy.port_clk7 = "port_unused"; defparam upll_memphy.port_clk8 = "PORT_UNUSED"; defparam upll_memphy.port_clk9 = "PORT_UNUSED"; defparam upll_memphy.port_clkena0 = "PORT_UNUSED"; defparam upll_memphy.port_clkena1 = "PORT_UNUSED"; defparam upll_memphy.port_clkena2 = "PORT_UNUSED"; defparam upll_memphy.port_clkena3 = "PORT_UNUSED"; defparam upll_memphy.port_clkena4 = "PORT_UNUSED"; defparam upll_memphy.port_clkena5 = "PORT_UNUSED"; defparam upll_memphy.self_reset_on_loss_lock = "OFF"; defparam upll_memphy.using_fbmimicbidir_port = "OFF"; defparam upll_memphy.width_clock = 10; 2. modify: defparam upll_memphy.port_clk7 = "PORT_UNUSED"; to: defparam upll_memphy.port_clk7 = "port_used"; 3. add following codes after instanced altpll upll_memphy(): defparam upll_memphy.clk7_duty_cycle = 50;defparam upll_memphy.clk7_multiply_by = pll_afi_half_clk_mult;
defparam upll_memphy.clk7_phase_shift = pll_afi_half_clk_phase_ps;
defparam upll_memphy.clk7_divide_by = pll_afi_half_clk_div;
4. find: assign afi_half_clk = 1'b0; modify it to: assign afi_half_clk = pll_clks[7]; note: Each time you re-generate Qsys system, you should do above workaround again... Hope this is usefule.:)
