13 years agoProblems with simulation of DDR2 SDRAM Controller with UniPHY
Hi, I Am using the files for simulation in generated for this IP . The IP is configured to enable Hard external memory controller, in Aria V, Quartus 12. The DDR2 SDRAM Controller is set...
13 years agoI have also noticed the problems with afi_half_clk when upgrading to Quartus 12.1 When digging into the generated code for the pll the second to last line is "assign afi_half_clk = 1'b0;" I am pretty sure that is the source of the problem there. For the time being i an creating an external Pll to divide down the clock.
-Brian
