18 years agoProblems using Video & Image Processing Suite
I have this problem when i wish to implement the suite using Simulink When i drag,say the scaler blockset, and double click it I received the following error message "Error evaluating 'OpenFcn...
18 years agoIt could be something isn't registered correctly, if your using the latest version of the tools (7.2) make sure you have the IP installed and a version of matlab that works with 7.2 (check the release notes). If your having issues you may want to try reinstalling DSP Builder.
Also, make sure if your using an existing MDL that it works for the version of DSP Builder your using. It could be that you have a older version of a demo that has an old version of IP, and you may not have that installed. x
