10 years agoproblems creating qsys component, understanding Avalon master& slave reads
Hi, what I am trying to do is building myself a InstructionCache Qsys component to use with the NiosII(e) as it lacks one. Since I found the Nios instructions to be 32 bits long and I thought...
10 years agoI have narrowed it further down to :
cacheValids(currentBlock0DescriptorIndex) <= '1'; and the cacheValids(currentBlock1DescriptorIndex) <= '1'; Its starting to occur to me that bulding memory with arrays might not be the best idea, how about I scap the internal memory idea and use several Static RAM IPs instead? Two static rams, one for the block memory and one in which I combine the tag + used + valid bit into one vector or better one big vector for both blockdescriptors ?
