11 years agoProblema with ip_compiler for PCI express under QSYS
Under qsys, if I insert a component "ip_compiler for PCI Express" , when generating HDL the following errors appear: Error (114000): Time value Mbps Mbps and time unit are illegal Error (114000)...
11 years ago --- Quote Start --- Mind share further on the configuration that you are using? I tried with my Quartus II 15.0 and seems like no issue generating the HDL. --- Quote End --- I can reproduce the problem by inserting the component "IP compiler for PCI Express" (the only one available for PCI Express for a Cyclone IV) with the default settings. That is, start with a clean design in QSYS (only the default clock), insert IP Compiler for PCI Express, and click "Generate". I am using Quartus II 15.0.1 for Linux, but I had the same problem with Quartus II 14.0 and 14.1
