11 years agoProblema with ip_compiler for PCI express under QSYS
Under qsys, if I insert a component "ip_compiler for PCI Express" , when generating HDL the following errors appear: Error (114000): Time value Mbps Mbps and time unit are illegal Error (114000)...
11 years ago --- Quote Start --- Under qsys, if I insert a component "ip_compiler for PCI Express" , when generating HDL the following errors appear: Error (114000): Time value Mbps Mbps and time unit are illegal Error (114000): Time value 125.0MHz MHz and time unit are illegal My FPGA is a Cyclone IV GXI am using Quartus II 15.0.1 --- Quote End --- Mind share further on the configuration that you are using? I tried with my Quartus II 15.0 and seems like no issue generating the HDL.
