10 years agoProblem with VIP suite on Cyclone V device
Hello, I am trying to work with VIP suite. My main objective is to read YCbCr 4:2:2 progressive 720x576 image from HPS DDR3 into the VIP suite using Frame reader , interlace the frame reader ou...
10 years agoThank you very much rsefton and Ted.
The test pattern generator output works fine with the pipeline running @54Mhz and the CVO pixel clock @27Mhz. The distortion or artifact was because of the display device, I changed the display device and the output looks perfectly fine. Now I shall proceed to testing with frame reader and mixer. Regards, Vidya
