10 years agoProblem with VIP suite on Cyclone V device
Hello, I am trying to work with VIP suite. My main objective is to read YCbCr 4:2:2 progressive 720x576 image from HPS DDR3 into the VIP suite using Frame reader , interlace the frame reader ou...
10 years agoIn the first post of the thread, you mentioned:
--- Quote Start --- I tried using test pattern generator , TPG(YcbCr,4:2:2,sequence,interlaced output)->CVO I get proper color pattern output. --- Quote End --- My suggestion would be to briefly retest that configuration and confirm that no distortion appears. If that configuration works well, it would point toward the addition of ITL+CPR blocks causing the issue. If TPG->CVO has the same distortion, then the issue is probably with the CVO not matching your hardware/display. Good luck.
