15 years agoProblem with signal compiler
I was working with DSP Builder, but today I couldnt, because signal compiler doesnt work, Many days before, I checked that quartus_map process run while signal compiler is running, but today ...
15 years agoUninstalling Java would make no difference, since it's included as part of Quartus.
What exactly does the MATLAB command "getenv JAVA_TOOL_OPTIONS" give you? Anything other than an empty string could cause problems.
