15 years agoProblem with signal compiler
I was working with DSP Builder, but today I couldnt, because signal compiler doesnt work, Many days before, I checked that quartus_map process run while signal compiler is running, but today ...
15 years agoI'll take your word for it on the CPU usage. It's a bit small for me to make out.
Do you do any Java development on your computer? Have you by any chance set the JAVA_TOOL_OPTIONS environment variable? (Use getenv in MATLAB to find out if you're not sure).
