15 years agoProblem with signal compiler
I was working with DSP Builder, but today I couldnt, because signal compiler doesnt work, Many days before, I checked that quartus_map process run while signal compiler is running, but today ...
15 years agoHello
The screenshoot shows the signal compiler and the task manager. The process quartus_map.exe is freeze with cero CPU resources. This situation not finish the compilation process. Thanks a lot dabuk
