16 years agoProblem with integer variable and vector range
My code: Int is an Integer Variable OutputNumber is a Std_logic_Vector Input Int <= conv_integer(OutputNumber); MyVector(37 downto (38-Int)) <= Temp(37 downto (38-Int)); Quart...
16 years agoAmilcar has already explained, that your code isn't valid VHDL. Try as I suggested or use a similar construct according to VHDL syntax rules.
