17 years agoProblem with DDR SDRAM controller (words swapped)
I'm using version 8.0 of the Altera DDR SDRAM controller to interface to a Micron MT46V16M16BG-6 SDRAM. The control signals between my local controller and the Altera DDR SDRAM block look fine when I...
16 years agoHave you entered board trace models into Quartus? You may have a lot of skew which quartus could correct.
What have you set the Address/Command phase to in the megawizard.
