xalverti
1 year agoProblem with CXL IP Design Example Type 3 on DK-DEV-AGI027RBES
Hi, We are using Quartus 24.1 to compile the type 3 ddr memory design example for the board and program the FPGA using the following guide: Agilex™ 7 R-Tile Compute Express Link* (CXL*) FPGA IP Des...
- 1 year ago
Hi again,
The problem was on the PCIe slot on the server side.
We replaced our card and the problem was fixed.
For anyone facing the same problems, we had to check the x16 slot with other devices to identify the lane drop issue in BIOS.
CXL IP designs apparently are note recognized in BIOS as PCIe devices even when the design is working -- the corresponding PCIe slot always shows the message "Link did not train" -- as if nothing is attached on the slot.
Thank you for your help,
Chloe
