16 years agoProblem with altpll output
I use EP2C8Q, the input clock connect the clk3 pin. the frequency is 27MHZ, I want to get higher frequency clock. I use the altpll to multiplier. The multiplication is 2 and 4. When I measure the out...
16 years agoConnecting PLL outputs through dedicated "pll_outxx" pins reduces the jitter. It's recommended, when low jitter is a design objective. But it's not generally required. In some designs, e.g. DDR RAM controller, regular IO is preferred for clock outputs to achieve particular timing constraints.
