16 years agoProblem with altpll output
I use EP2C8Q, the input clock connect the clk3 pin. the frequency is 27MHZ, I want to get higher frequency clock. I use the altpll to multiplier. The multiplication is 2 and 4. When I measure the out...
16 years agoPll_out connection isn't critical in this regard. PLL power supply is most critical, as said, also signal quality of clock input. Also a large amount of simultanaeous switching FPGA outputs can promote PLL loss of lock.
