17 years agoProblem with AD/DA Conversion
Hello, I'm trying to design a simple Project to understand the use of my Stratix II 2S60. This project is a AD/DA converter. I display a counter 0-F on an LED, transfer it via my DAC to my AD...
17 years agoIf you are using Stratix II DSP Dev Kit (most likely), it has AC-coupled DAC and ADC, your test doesn't work there. Use the example designs provided with the Dev Kit to check DAC/ADC operation.
