14 years agoproblem while displaying D5M image data on LCD using VIP core
Hi all, I'm trying to use the D5M camera and an LTM LCD touch screen connected to DE4 board using Altera VIP open core. The block diagram of my design is described in the attached picture. In Nios...
12 years agoHi gladys!
I am working a project: use D5M camera and VGA connected to SocKit Cyclone Evaluation. I look over your block diagram above that likewise to my design.I config D5M with raw 1280x960. After out of "RAW2RGB" block , i have data format 640x480 and follow by Clocked Video output, then RGB 640x480 is directly connect with LCD. Result is not good,. I attached image that I capture a lamp, it only has 2 colours: white and black, not RGB???? I am stuck for more than 1 week. Could you give me a hint! Thank you so much!https://www.alteraforum.com/forum/attachment.php?attachmentid=8945 https://www.alteraforum.com/forum/attachment.php?attachmentid=8946
