14 years agoproblem while displaying D5M image data on LCD using VIP core
Hi all, I'm trying to use the D5M camera and an LTM LCD touch screen connected to DE4 board using Altera VIP open core. The block diagram of my design is described in the attached picture. In Nios...
14 years agoHi again, I've solved the problem, it's encouraging, I did what you said to test backward step by step, it turns out to be the the video input problem, I got to reset the i2c parameter of the cmos sensor and the problem was fixed. Now I have synchronized image. Thank you so much ra2m for your kind help.
