15 years agoProblem Using FIR ip core 9.0
Hello, I'm trying to implement a band pass filter using FIR Compiler IP Core (ver. 9.0). My input is a 24 bit signal. My output should also be 24 bit. I'm getting 36 bits output from the wiz...
15 years agoHi,
thank you. I didn't quite understand how this formula can help me decide how many MSBs and LSBs I need to cut... and I tried your method and my FIR still attenuates the signal. Can I please get an example of a Band Pass Filter settings? thank you very much! asaf
