16 years agoProblem simulating DDR2 SDRAM Controller with ModelSim
I use Quartus 9.0 SP2, ArriaII GX and a DDR2 SDRAM High Performance Controller in my FPGA design. I have used the EDA Simulation Library Compiler to generate the compiled libraries for ModelSi...
16 years agoHi connational,
I tried your suggestion, now actually doing with your script (modified) the same job NativeLink was supposed to do. I end up with the same error(!) I have actually had to manually edit arriaii_atoms.vhd (the one Altera provides!) to fix the bug. Library declarations around line 16791 were wrong and I had to change them to: LIBRARY IEEE; LIBRARY altera; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.VITAL_Timing.all; use IEEE.VITAL_Primitives.all; use altera.all; use work.arriaii_atom_pack.all; This way I got rid of the error ""regn : dffeas" is not bound" etc. Now the DDR2 simulates but sadly the local_init_done signal never becomes 1. There must be some other bug... I will upgrade to the latest Quartus and DDR2 HP IP and let's see if it helps... BTW, I'm just trying functional simulation, not post synthesis, no problem.
