16 years agoProblem simulating DDR2 SDRAM Controller with ModelSim
I use Quartus 9.0 SP2, ArriaII GX and a DDR2 SDRAM High Performance Controller in my FPGA design. I have used the EDA Simulation Library Compiler to generate the compiled libraries for ModelSi...
16 years agoHello,
unfortunately for you I am not a guru but some weeks ago I used Modelsim SE 6.5c to simulate DDR2. I did not used native link to compile the simulation libraries but I followed the procedure below: 1) copied the sources of the simulation libraries into a new modelsim project 2) modified and used the script at page: http://www.altera.com/support/examples/download/vhdl-library-setup.tcl?gsa_pos=3&wt.oss_r=1&wt.oss=vhdl%20library%20setup (modified because this is for qII 7.1 ad I used qII 9.0 libs) 3) copied the compiled libs to modelsim directory and edited modelsim.ini to point at them I would not suggest you to use this procedure but you may look at the commands used in this script and the ones used in nativelink scripts and spot the differences... Eventually, if guru's answers are on a different timezone, try both variants of the commands. I saw a man use the precompiled libraries from Modelsim Altera in Modelsim SE... NOTE: Don't lose time on simulate the DDR2 HP Controller in post synthesis or post place and route... it is based on Altmemphy which can not suppor post synthesis simulation. You will find this info in Altmemphy manual
