14 years ago
Problem running pin_assignments.tcl script with uniPHY DDR3 controller
I'm experiencing some problems with SoPC builder and quartus 11.0.
Why SoPC builder and not Qsys ? Because I use an IP that is'nt yet avaible with Qsys...
I did a very simple project with SoPC buider :
For a Stratix IV device :
- Nios II processor
- DDR3 controller with uniPHY
Building the system with SoPC builder is OK. Analysis & Synthesis are OK.
After that I did : Tools -> Tcl scripts, then I selected and launched <>_pin_assignments.tcl script.
Here is the log (tcl console) :
ERROR: Argument <node_object> is an object filter that matches no objects. Specify one matches only one object.
    while executing
"get_node_info -cell $node_id"
    (procedure "is_node_type_pll_clk" line 2)
    invoked from within
"is_node_type_pll_clk $pll_output_node_id"
    (procedure "get_input_clk_id" line 2)
    invoked from within
"get_input_clk_id $pll_ck_clock_id"
    (procedure "ddr3top_p0_get_ddr_pins" line 237)
    invoked from within
"ddr3top_p0_get_ddr_pins $instname allpins"
    (procedure "ddr3top_p0_initialize_ddr_db" line 13)
    invoked from within
"ddr3top_p0_initialize_ddr_db ddr_db"
    (file "D:/dev_fpga/test_ddr3_11/sopc/ddr3top/altera_mem_if_ddr3_phy/ddr3top_p0_pin_assignments.tcl" line 191)
If someone has an idea... Similar projects worked well with the same procedure with Quartus 10.1...
Thank you.
    Here is an example of a Python script which can do all the job for you, just replace the path and the name of your top level entity generated sy SoPC builder :
    f = open('./src/sopc/your_sopc_top_level.vhd')
    text = f.read()
    f.close()
    new_text = text.replace("mem_cas_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_cas_n : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_ck : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_ck : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_ck_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_ck_n : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_cke : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_cke : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_cs_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_cs_n : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_odt : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_odt : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_ras_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_ras_n : OUT STD_LOGIC;")
    new_text = new_text.replace("mem_we_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0)", "mem_we_n : OUT STD_LOGIC")
    new_text = new_text.replace("mem_cas_n(0)", "mem_cas_n")
    new_text = new_text.replace("mem_ck(0)", "mem_ck")
    new_text = new_text.replace("mem_ck_n(0)", "mem_ck_n")
    new_text = new_text.replace("mem_cke(0)", "mem_cke")
    new_text = new_text.replace("mem_cs_n(0)", "mem_cs_n")
    new_text = new_text.replace("mem_odt(0)", "mem_odt")
    new_text = new_text.replace("mem_ras_n(0)", "mem_ras_n")
    new_text = new_text.replace("mem_we_n(0)", "mem_we_n")
    f = open('./src/sopc/your_sopc_top_level.vhd', 'w')
    f.write(new_text)
    f.close()
