9 years agoProblem on Linux PCI Express driver for an Avalon-MM DMA reference design
Hi I'm Joel
I'm trying to use the PCI Express Avalon-MM DMA reference design (https://www.altera.com/products/reference-designs/all-reference-designs/interface/ref-pciexpress-avalonmm-hp.html) but I'm having some troubles with the Linux driver. I'm working on an Ubuntu 14.04 LTS, 64 bits machine. I've already my Stratix V FPGA plugged in the PCI Express port of my computer. Using instructions in the literature (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an690.pdf), I used the command "sudo make" to compile the driver. When I run the "sudo ./install", I keep having the error displayed in "installation_error.png". Though I'm having that error, when typing "lsmod" I see that the module altera_dma is well loaded into the kernel. At this point I'm not sure about how to fix that, I know the problem is that there is no file /dev/altera_dma and because, of that I can't run the user application as depicted by "run_error.png" Please can you help? Do you have any idea of what might be wrong? Best regards6 Replies
To fix this I just modified the Device ID. It was initially 0xE003. I changed it to 0xE001 (this one is the default Altera's PCIe Reference Design Device ID). It can also be found in the SoC design when opening QSYS
Hi Joel,
I am having the same problem with https://www.altera.com/en_us/pdfs/literature/an/an690.pdf, pretty much the same but I am using a Cyclone V. I can see from the reference design specs the default device ID is the same as you mentioned above: 0xE003. Where exactly did you modify it? In any of the files for the driver/application on the host side? Did you modify it in the QSYS design? Kind Regards, Aidan - Altera_Forum
Hey Aidanob
If you go to "altera_dma_cmd.h", at line 6 you'll find # define ALTERA_DMA_DID 0xE003. The Device ID registered in your operating system and the one in the driver code must match. In my case, the device ID of my Stratix V FPGA board was 0xE001 from my operating system standpoint, so I had to modify the default value specified in the driver code. To check what device ID your operating system is seeing you can try doing: - lspci - cat /proc/bus/pci/devices |grep Altera "lspci" should give something like: Altera Corporation Device e001 (rev01). That "e001" is your device ID --- Quote Start --- Hi Joel, I am having the same problem with https://www.altera.com/en_us/pdfs/literature/an/an690.pdf, pretty much the same but I am using a Cyclone V. I can see from the reference design specs the default device ID is the same as you mentioned above: 0xE003. Where exactly did you modify it? In any of the files for the driver/application on the host side? Did you modify it in the QSYS design? Kind Regards, Aidan --- Quote End --- - Altera_Forum
Hi Joel,
Thanks for the detailed and clear response! Kind Rgds, Aidan - Altera_Forum
Hi Joel,
Thank you for sharing you experience! I am encountering the same problem. The only difference is that I am using a Arria-10 Dev Board. I tried to follow your instruction but soon found that the output of lspci shows that I should use 0xE003 as DID.
May I ask if there's any other step you took between changing the DID and seeing /dev/altera_dma showing up? Did you have to unplug/plug the FPGA, and/or reboot the host machine? Any suggestion is much appreciated! --- Quote Start --- Hey Aidanob If you go to "altera_dma_cmd.h", at line 6 you'll find # define ALTERA_DMA_DID 0xE003. The Device ID registered in your operating system and the one in the driver code must match. In my case, the device ID of my Stratix V FPGA board was 0xE001 from my operating system standpoint, so I had to modify the default value specified in the driver code. To check what device ID your operating system is seeing you can try doing: - lspci - cat /proc/bus/pci/devices |grep Altera "lspci" should give something like: Altera Corporation Device e001 (rev01). That "e001" is your device ID --- Quote End ---# lspci | grep Altera 01:00.0 Non-VGA unclassified device: Altera Corporation Device e003 (rev 01) - Altera_Forum
I have the same issue. Is there any workaround btw? Best Regards
