14 years agoproblem of adding custom component in SOPC
Hi~~ My SOPC setting have processor,PIO,SDRAM,FLASH..so on. I want to add a custom component which is a simple counter IP. (behavior: when I push the switch ,then the counter will plus...
14 years agoI'm afraid I neither have a DE0 board nor I ever used Linux kernel, then I can't help you on this point.
You'd better start a specific thread in the Linux or in the Development Kit section of the forum. But before this, I recommend you search the forum an answer: this could be a common issue.
