17 years agoproblem about altlvds PIN assignment!
I want to use the altlvds megafunction to receive 500Mbps data(width=1),and the deserialization factor is 2.But now I face a strange problem: if i use verilog to implement the function and assig...
17 years agoWhat do you mean when you mention submit an SR? to whom?You mean timing sim is not worth doing? But from RTL sim you can only see if it is implemented as what you think,you can't tell the accurate timing.From my opinion,isn't timing sim static timing analysis?
