12 years agoprevent write/write collision in on-chip True Dual Port Ram
Hi, FPGA: Cyclone V SoC On-chip Memory: Ram, True Dual Port, single clock, Old_data Two NIOS will have access to the ram (NIOS A to Ram port S1, NIOS B to Ram port S2) In Altera docume...
12 years agoYou only have to worry about concurrent writes to the same memory cell.
Read up on Dekker's algorithm, and use it to get the required exclusive access. Or just arrange the interface so that the code ensures that both cpus are never going to write to the same location at the same time. I just found http://cs.stackexchange.com/questions/12621/understanding-petersons-and-dekkers-algorithms The 'turn' location could be written concurrently by both cpus, but if you just test odd/even in the Peterson case that won't matter.
