12 years agoprevent write/write collision in on-chip True Dual Port Ram
Hi, FPGA: Cyclone V SoC On-chip Memory: Ram, True Dual Port, single clock, Old_data Two NIOS will have access to the ram (NIOS A to Ram port S1, NIOS B to Ram port S2) In Altera docume...
12 years agoHi HBS:
The most efficient solution is to limit memory ranges, so NIOS A can write, only X range but read Y range, and NIOS B can only Write Y range but Read X range. Now you eliminate the issue where both write to the same address (unless you have a coding memory leak) If you are going to allow both processors to write to all the memory, then I suggest you make one the Memory Manager, where the second processor must request, then receive approval for that memory access from the "Master" processor. This avoids timing conflicts, where Processor A and B both want to write, they check, and the other processor is not writing, so they both set their write bit and start writing at the same time.. Pete
