17 years agoPost-fit simulation of NCO MegaCore
I have a simple test project with a MegaCore NCO. I can do functional simulation using the .vho file, but the netlist generator refuses to create an .sdo file:
Error: Can't generate netlist output files because the file "C:/Altera/90/DrJohn/NCOtest/incremental_db/compiled_partitions/NCOtest.root_partition.map.atm" is an OpenCore Plus time-limited file Does this mean that it is impossible to do post-fit simulation with MegaCore functions? Or is it because I don't have the correct license? Thanks, John1 Reply
because of the license...
--- Quote Start --- No .vqm, or atom-level .vo, or .vho files are generated. The bottom-up incremental design flow is also not supported. --- Quote End --- http://www.altera.com/literature/an/an320.pdf
