15 years agoPoor performance with PCIe and DMA on Linux
Hello all, I built a evaluation system on the Arria II dev board that transports two similar datastreams to a linux host so that each stream can be read from a different device file. The s...
15 years agoHello again,
I did more tests. I doubled the datawidth from 32 bit to 64 bit. The fifos write doublewords so the throughput is doubled in theory, because the pcie-tx-port ist 64 bit wide. In fact the throughput isn't better now. If I increase the DMA-block-length, the whole card freezes. The PCIe-interface sets waitrequest and stays in an that state. The card does not react to any command until I reset it. If I put debugging messages into my driver's code, the block length can be bigger, because it takes time until the next dma-request. This issue occured with singleword transfers, too. Does anybody has an idea? Regards, Frederik
