14 years agoPoint me in the right Direction - PCIe
Ok - Ive been staring at the PCIe Userguide for a couple of days - and I dont really know where to start with this thing. We have a design that requires the following setup: PC (currently windo...
14 years ago --- Quote Start --- The PCI spec probably makes slightly easier bedtime reading! --- Quote End --- The PCIe spec is $3500. http://www.pcisig.com/specifications/order_form I doubt it is worth reading though. It'll be mostly about electrical and PHY layers that are taken care of by the Altera IP. The specifications worth reading are the ones related to the physical form factor you are putting the card into, eg., Compact PCIe (or whatever they call it), AdvancedTCA, AdvancedMC, etc. Those specifications are about $100 to $400 each from PICMG. https://www.picmg.org/v2internal/specorderformsec-nonmember.htm But you can also become an affliate member for $1000 and you get everything (a stack of specifications about a foot high). That's my recommended bedtime reading :) Cheers, Dave
