14 years agoPoint me in the right Direction - PCIe
Ok - Ive been staring at the PCIe Userguide for a couple of days - and I dont really know where to start with this thing. We have a design that requires the following setup: PC (currently windo...
14 years agoThe PCI spec probably makes slightly easier bedtime reading! Once you'e loosely understood a bit about how the bus works (logically that is), you can then think a bit about PCIe. PCIe is basically PCI using hdlc frames instead of a parallel bus.
The Altera PCIe slave isn't fast - when fed through PCIe->Avalon interface single cycles are positively lethargic (think ISA bus speeds, then slow it down some). Fortunately a PCIe transfer can carry a lot of bytes (probably 128) and the per-byte cost is small. Unfortunately you (almost always) need to start with a DMA engine in order to do multi-word cycles.
