15 years agoPlease, advise me how to improve the performance of my verilog module
Hi, exercising on DE3 Terasic board, I meet a situation that I cannot find myself a solution of my questions and kindly ask this forum to advise me. I have small verilog module that reads ...
15 years agoHi,
Quartus will infer the four multipler adder mode from your Verilog, if it follows a suitable template. Check the Quartus manual, section 6-9, for details and examples. http://www.altera.com/literature/hb/qts/qts_qii51007.pdf That said, I don't see how it will help your with your resource problem: a Stratix III DSP block can implement 4 18x18 multipliers, weather it's 4 independent multipliers or 4 multipler-adders. As for fMax, you need to take a look at your critical paths and see where the largest delay is. In such a case, adding some extra register stages might help. PS: your "artificial block" looks like something that will be synthesized to latches.
