15 years agoPIO performance
Hi, I use IORD and IOWR to control the PIO and it seems the speed will be no more than 15MHz. Is there any way to accelerate?
15 years agoIt's pretty easy actually. With the DMA you basically read a buffer from memory and have the DMA write to a fixed address. The bit in the control field for writing to a fixed address is called "WCON" I think. There is something similar in the SGDMA but I forget what the bit is called. Take a look at this design, it does something similar: http://www.altera.com/support/examples/nios2/exm-crc-acceleration.html (http://www.altera.com/support/examples/nios2/exm-crc-acceleration.html?gsa_pos=1&wt.oss_r=1&wt.oss=crc)
