15 years agoPin Assignment Error
Hi, Can anyone help me with this error in quartus. I am using DDR2 memory with EP3C120F780C7 DDR2: U25 and U26 bottom chip I think there is some problem with the pin assignment to the ...
14 years agoHi,
I got a solution. You just have to add in the Pin Planner a new Column to the Groups and assign a interger variable to that group where the pins which cause this error. See also Altera 5. I/O Management And here take a look at the following part: Optimizing I/O Assignment Analysis with Output Enable Group Logic Option Assignments
