Pin allocation for PCIe HIP gen 2 x1 with Avalon-MM Interface
Hi @CaptainPrice15 ,
Do you use this pin for configuration purpose ?
IF not, you have the option to select 1.2V, 1.5V, or 1.8V compatible I/O standard.
Detail please refer below
https://www.intel.com/content/www/us/en/docs/programmable/683417/current/optional-dual-purpose-configuration-pins.html
Wincent_Altera
Hello @Wincent_Altera
Thanks a lot for your reply. No, I do not need the pin for configuration purpose. I have read the document you provided in your reply and do understand that I have the option to select 1.2V, 1.5V, or 1.8V compatible I/O standard. That being said, as seen in the screenshot I attached in one of my previous replies, the Quartus software doesn't allow me to allocate the nPERST pin to any other IO. It is reluctant that I assign the pin AB11 to it; which is unfortunately not possible for me.
- Wincent_Altera1 year ago
Ho @CaptainPrice15 ,
>> Sorry I missunderstanding your question, thanks for clarified.
>> If I go through the device schematic diagram https://cdrdv2-public.intel.com/649849/c10gx-dev-kits-board-a1-release.pdf
>> AB11 was only PCIe_perst that we have for this device
>> As it is only perst for PCIe, we are suggest to use AB11.
Regards,Wincent
