17 years agoPhy Input Clock DP83848C PHYTER
Hi , I am using Altera CYCLONE III ,I have implemented NIOS II + Onchip memory + SSRAM + Custom MAC (RMII Mode).I want to configure the PHY to RMII Mode.For that I think I have to connect 50 M...
17 years agoHi ,
I looked at the schematic.The X1 Pin is connected to a crystal oscillator . I am attaching the schematic here.Refer Page 3. I want to know whether we have options to configure the Crystal oscillator to generate a 50MHz clock or externally we have to connect 50MHz clock.If So I don't know how to make the things happen ? I am attaching the PHY Document also . There is one particular register in PHY to configure in RMII Mode [Register No 0x17,]If I configure it to RMII Mode , whether 50 MHz clock will be generated ? If this happens No need to configure the crystal oscillator for 50 MHz / external clock connection .
