14 years agopciex4 ip core on cyclone iv gx F27
I have designed and data acquisition card. it uses pcie x4 interface to communacate with the host computer. the card is base on an cyclone iv gx 50 F672 fpga device, the quartus ii software ve...
14 years agoThanks for Socrates's reply.
my problem is below: compilation succeeds pin assignment: ...... set_location_assignment pin_t14 -to refclk set_location_assignment pin_t15 -to "refclk(n)" set_location_assignment PIN_AA2 -to rx_in0 set_location_assignment PIN_W2 -to rx_in1 set_location_assignment PIN_U2 -to rx_in2 set_location_assignment PIN_R2 -to rx_in3 set_location_assignment PIN_Y4 -to tx_out0 set_location_assignment PIN_V4 -to tx_out1 set_location_assignment PIN_T4 -to tx_out2 set_location_assignment PIN_P4 -to tx_out3 compilation failed pin assignment: set_location_assignment pin_t9 -to refclk set_location_assignment pin_u9 -to "refclk(n)" set_location_assignment PIN_AA2 -to rx_in0 set_location_assignment PIN_W2 -to rx_in1 set_location_assignment PIN_U2 -to rx_in2 set_location_assignment PIN_R2 -to rx_in3 set_location_assignment PIN_Y4 -to tx_out0 set_location_assignment PIN_V4 -to tx_out1 set_location_assignment PIN_T4 -to tx_out2 set_location_assignment PIN_P4 -to tx_out3 the error message: Info (167065): Input frequency of fixedclk for the GXB Central Control Unit "ip_pciex4_example_chaining_pipen1b:core|ip_pciex4_plus:ep_plus|ip_pciex4:epmap|ip_pciex4_serdes:serdes|ip_pciex4_serdes_alt_c3gxb_7ue8:ip_pciex4_serdes_alt_c3gxb_7ue8_component|cent_unit0" must be 125.0 MHz error (176559): can't place mpll or gpll pll "ip_pciex4_example_chaining_pipen1b:core|ip_pciex4_plus:ep_plus|ip_pciex4:epmap|ip_pciex4_serdes:serdes|ip_pciex4_serdes_alt_c3gxb_7ue8:ip_pciex4_serdes_alt_c3gxb_7ue8_component|altpll:pll0|altpll_nn81:auto_generated|pll1" in pll location pll_5 because i/o cell "refclk" cannot be placed in i/o pin pin_t9 (port type inclk of the pll) Info (171121): Fitter preparation operations ending: elapsed time is 00:00:02 Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information. Error (171000): Can't fit design in device Warning (169177): 2 pins must meet Altera requirements for 3.3-, 3.0-, and 2.5-V interfaces. For more information, refer to AN 447: Interfacing Cyclone IV GX Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems. Info (169178): Pin pcie_rstn uses I/O standard 3.3-V LVCMOS at U19 Info (169178): Pin local_rstn_ext uses I/O standard 3.3-V LVCMOS at W26 Error: Quartus II 32-bit Fitter was unsuccessful. 2 errors, 14 warnings Error: Peak virtual memory: 335 megabytes Error: Processing ended: Sun Jan 29 10:47:12 2012 Error: Elapsed time: 00:00:12 Error: Total CPU time (on all processors): 00:00:10 Error (293001): Quartus II Full Compilation was unsuccessful. 4 errors, 535 warnings but, my card select the failed pin assignment. please help fix the problem.
