13 years agoPCIe transceiver offset cancelation
Device - Stratix IV Using PCIe x4 Gen2. For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using th...
13 years agoThanks again Dave!
Let me get back and do some more checking, I was thinking that the reset might be pulled up high at power-on and host asserts the reset once the BIOS chip is powered up and host starts its enumeration sequence. I will check more on the timing aspect of things and get back with more data, And thanks for sharing the documents, its a really good one. I need to read that.
