13 years agoPCIe transceiver offset cancelation
Device - Stratix IV Using PCIe x4 Gen2. For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using th...
13 years agoThanks Dave! I had in fact gone through the document you mentioned about deglitching the reset, but I didn't experience any issues so far without it, I guess I was just lucky.
I will try to use an internally generated reset pulse and see if that works. I will post the results tomorrow. And I have to read this, good document http://www.ovro.caltech.edu/~dwh/wbsddc/ts4_power.pdf. Thanks!
