13 years agoPCIe Simulation : PCIe Root Port BFM transactions
Hello, I want simulate, with Modelsim, an Altera PCIe Endpoint design Qsys-Avalon-MM based. I begin starting with the PCIe Qsys example in Chapter 17 of the "IP Compiler for PCI Express User ...
13 years agoHi Tricky,
You talk about Avalon-ST interface. I don't want to be a PCIe expert, TLP's, credits, data alignment...and so. The only thing I need, is a plain parallel bus interface, so I discard using Avalon-ST. Although the Avalon-MM is not available as standalone IP using Megawizard (thanks Altera :evil:). Avalon-MM it's the interface I'll use.
