14 years agoPCIe problem with large TLPs
I'm sending a TLP (from the application layer) of 4 headers and 128 bits of data (Avalon-TX 128). Headers look like this: header0 = 32'h60000004; //fmt = 3, length = 4 DW header1 = 32...
14 years agoThe PCIe spec says:
--- Quote Start --- • For Addresses below 4 GB, Requesters must use the 32-bit format. --- Quote End --- So, in your TLP generator you have to check the upper 32 bits of the address to be zero and use a 3 word TLP in this case.
