15 years agoPCIe polarity inversion Setting
I am using Altera PCIe x4 Soft IP 9.1 with a 2SGX60E device. As a result of the pcb layout, I have to reverse the polarity of the diffential pairs in both the receiver and the transmitter. To i...
15 years agoWell, I do see in the pci express base spec that all PCIe receivers are required to to support automatic polarity inversion(Rev1.1,page56). But meanwhile in the stratix ii gx transceiver architecure overview, Altera says:
"The positive and negative signals of a serial differential link are often erroneously swapped during board layout. Solutions like a board re-spin or major updates to the PLD logic can prove expensive. The receiver polarity inversion feature is provided to correct this situation. An optional rx_invpolarity port is available in all single-width and double-width modes except (OIF) CEI PHY to dynamically enable the receiver polarity inversion feature..." Now that automatic polarity inversion in the link layer is supported, the optional rx_invpolarity port seems unnecessary to most people. What is it designed for? Despite of these, I believe that you're right. I don't need to explicitly change the megafunction files.
